Dual Tariff or dual RCD | Page 2 | on ElectriciansForums
Discuss Dual Tariff or dual RCD in the UK Electrical Forum area at ElectriciansForums.net
london
Hello everyone
I currently need to change a dual tariff (economy 7 & on peak) consumer unit situated inside a flat.
One half of the existing split fuse board serves the storage heaters with the second separate half being the On peak supply.
Am i correct in thinking a standard dual RCD board is effectively a dual tariff DB.
Just making sure i am not being a numpty in my thoughts? which is quite often the case.,
Yeah you are defo right there I will defo bring this up with the firm I work for.
You also should mention
â—Ź Conductors not enclosed into the dist board.
â—Ź Correct identification of the swa conductors.
â—Ź The yellow conductor is oversized to enable suitable termination at the earth bar and hence strands have been cut away.
â—Ź Generally all conductors are poorly terminated especially the secondary neutral at the main switch.
â—Ź The consumer unit has been altered beyond manufacturers recommendations.
and I may has well put ,that neutral to the rcd side to the s/heaters not marked up for the line .I have seen a lot like that .
Reply to Dual Tariff or dual RCD in the UK Electrical Forum area at ElectriciansForums.net
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
