M
matthewcoxall12
i will tell the story as i know it and be aware i have about 1% electrical knowledge just what i have picked up along the way
this is a picture of the wiring set-up i have on my Lister d now this set-up has been tested and i ran a 240 v drill and then a 240 sander with the voltage meter decreasing at a very very very slow pace nothing to be worried about for a day rally so i thought great lots of power i was not going to complain about where it was coming from (as its a 12v dynamo attached to a 12v battery running a 240 drill at full speed) anyway i picked up one of those old spinning police lights the other day at the boot sale and i thought i would give it a test on the dynamo so i wired it up as all i got was a tiny little glow from the bulb and the thing was not spinning. thinking the light was broke i got out the 12v power pack and tested it and away it went perfectly so attached it back up to the dynamo and the same only a tiny glow from bulb and no spinning so my question is how can my dynamo produce enough power to run my drill and sander but not enough power to run a 12v light
the drill and sander are new not old and i did try the light on the red and blue wire that goes into the plug the same red and blue wire that runs the drill through the plug
so after all the agro i have been having i wanted to really put the dynamo to the test and the results are in the video
[video=youtube;f9zdbZN2hmE]http://www.youtube.com/watch?v=f9zdbZN2hmE[/video]
the little 12v battery voltage droped but my car battery held its voltage till i turned the engine off did not drop at all for the whole hour i ran the engine
What voltage do you get across the alternator / dynamo ??
Put the test leads where you have the red and black lead froming from it, without the battery connected. I think what you have there is a small 220V alternator, the battery is exciting the stator windings, which is why it drains down after a while.
on another note, is that a lister water pump on the top right of the video?
yes i think you might be right i think he covered it himself some how i know it use to be a dynamo
and it a climax well pump head will be shown with the engine cheers
dynamo headache
Australia
matthewcoxall12,
matthewcoxall12,
