Earth and bonding cable checks-any tools available? | Page 7 | on ElectriciansForums
Discuss Earth and bonding cable checks-any tools available? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Let's help the guys out here is not their fault, but as we can't see the job or any known values I would always air on the side of caution & say go with a good piece of cable say 35mm to gas & water should not be an issue then, be fun pulling it in & terminating, after all these cookers are pretty big these days.
I'm still here, just been silenced by all the digs!
If we/they are doing something you feel is incorrect, why not just state so?
When I said 'installation' I meant the installation of the appliance not the electrical installation, as in:
Zs=as in the max measured EFLI from the point of connection of the circuit, ie where the cooker is installed as it's a radial.
So you need to ensure the CCC of the cable is adequate for the appliance if supplied on a dedicated radial. Or meets VD and Zs values if connected to a circuit that feeds several points?
Well why didn't you say that in the first place????!!! :frown2:
On this little forum we have folk of many trades who have a vast array of skills and talents which makes us a formidable force of knowledge but there is one skill that NONE of us have and that is .......mind reading!!
Give us ALL the info in a clear and concise order and you'll get all the help you need - and more!. BUT **** about giving incomplete information in dribs & drabs and WE'LL **** about - and THAT is something that we excel in! :sailor:
Hi All,
Just a quick question, I need to get my gas & cooker installers to check earth and bonding conductor presence and sizing, (reg 132.16) what tool, if any, would you recommend? Such as a cable gauge or caliper etc.
What do you guys use, apart from your eyes and experience?
I' d appreciate you suggestions.
Thanks in advance.
So back to the OP:
What exactly are you as a business doing?
What competence do you have?
What competence do your "guys" have?
Do you all have MFT's?
Answer these and then maybe you will get some straight answers!
If you don't I'll need to brush off my crystal ball.
Hi again Dillb;
The installers are doing all of the above and are OK with that.
They are now expected to confirm main earth and bonding CSA are up to spec. as requested by NICEIC, but as we all have stated in the thread, it's not that easy for a non 'sparky' to do this.
Thanks for all the help and feedback too. Next post I will ensure I word it correctly and keep it simple
So back to the OP:
Hi again Murdoch,
Thanks for the reply,
-The guys install electric and gas cooking appliances
-I'm an electrician
-The guys are electrically competent in their world i.e. installing electric cooking, but aren't electricians
-Yes, they all have Fluke 1653s
I didn't word the OP very well, all I was trying to ask was how could an inexperienced person identify the earth and bonding conductors CSA. I really must read things before I post.
Anyway thanks for all the help and banter!
I've learnt the hard way Geordie! Next time I'll try and cut the sh*te and ask the correct question.
Thanks for all the feedback and banter!
Reply to Earth and bonding cable checks-any tools available? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Was there any toast to go with the beans? Just joking I think that you ment beams and not beans I am dyslexic and simple mistakes tend to jump out...
2 3
