B
BillyTheSparks
Hi De Hi,
I'm pricing for a small kitchen extension.
The owner of the property has run a 10mm^ 3core SWA around the outside of the building from the garage to supply a new C/U in the kitchen.
All well so far.
The problem is that the Main Water and Gas has not been bonded to the MET!
The water stop cock has been tiled in to some boxing in the shower room, and is unaccessable!! And both are situated the wrong side of the house to the C/U.
It will a pain to have to get the original C/U going under the floors as they have fitted wardrobes/furniture and the joists run the wrong way (typical!!)
As said the SWA is 10mm^ 3core.
Would it be possible to bond the Gas and Water from the new C/U; in the new part of the kitchen?? Using the earth of the SWA (I was going to use the 3rd core as an earth for the new circuits.
Any help would be greatly appreciated
All well so far.
