earth leakage | Page 2 | on ElectriciansForums
Discuss earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
a friend of mine told me he uses the clamp meter for his ir tests dosent do any ir testing just calculates the ir from the leakage current he detects whats your thoughts on that says it saves him lots of time still need convincing that this is ok
I use that method on jobs where I need to know the ir but can’t turn the power off
Does sound dodgy ,if no one else can get same figure with 500V .
Can see where he is coming from Not having to unplug all those delicate electronics (they get tested at 380-400VDC)
Wot I need power factor in my clamp meter ?
Not sure what you mean?
So if using an EL clamp to calculate IR you would be calculating the impedance as the insulation has a capacitive reactance..
We use dc voltage to measure just the resistance and the capacitive component is ignored.
Insulation impedance (including capacitive reactance that could raise current ,but not power consumption... Hence appearing a little lower Z than actual R.
Was hoping for some amazing science ,(but with only the current -It cannot know the phase of the voltage to {filter-out} capacitive part of current )
Not to matter.
Reply to earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not a reliable indication of a fault! What RCD characteristics (and also why is an incomer needed here)? Have you done a global L+N IR test to...
