Earth rod, RCD tripping fault | Page 2 | on ElectriciansForums
Discuss Earth rod, RCD tripping fault in the UK Electrical Forum area at ElectriciansForums.net
J
Jel
1st question:
Had to install a earth Rod in rural area today because the Ze on the current TN-S system was too high.
All the circuits are brand new, but for some reason a circuit with LED Haler downslight on seem to trip when the systems earth is changed to the earth rod. The Ze of the system is 11.1ohms.
Every other circuit is fine.
2nd Question:
As my Ze is higher, all the readings im getting for my Zs are too high, but would i be right in thinking they circuits meet the disconnection times because of the RCD, so the high Zs does not matter?
Being stupid, as their was no main earth bonds connected thought it would be ok.
Have not been able to test inside the house yet as owner are away till next week, but i have had major issues with DNO lately and Ze being too high and they will not do anything about it as they say they do not maintain the earth?
because if it is and the DNOs equipment is already being used as the means of earthing to this property ..clearly it is (TN-S)....then they have a duty of care to maintain this arrangement......
I have had 2 flats i tested in london in the past 2 months where DNO will not sort out high Ze. Has been a nightmare!
Reply to Earth rod, RCD tripping fault in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
