earth rod test | on ElectriciansForums
Discuss earth rod test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
ambrad
Hi All
When testing a tt system, if you cant locate the earth rod is it ok to carry out a ze test for that supply and put a limitation in the earth rod section of the test cert.
if not can anyone suggest how to obtain the correct resistance measurement with only the earth cable at the board accesible.
thanks
If you are doing an EICR and the rod is under paving or floorboards, then you are a bit stuck, however this would be an operational limitation.
But it is a critical safety point so if you can find it it would help, if you are unable to check the labeling and security of the connection you do not know how safe it is.
But if you are getting a decent Ze reading then at that time it is OK.
Probably a further investigation required.
thanks richard.
do you think the ze measurement would be representative of the resistance reading for the rod, or is this an assumption that cannot be made.
I am happy to put a limitation in the section regarding the type of rod etc but a figure in the resistance of the rod would be good.
Would the ze be this figure.
Ze is an acceptable estimate for the true Ra of a rod, the difference in resistance will be likely less than 0.5 ohms (the resistance of the line conductor back to the substation) and will not make a significant difference to the value.
Reply to earth rod test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
2 3
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
