Earthing Arrangement | on ElectriciansForums
Discuss Earthing Arrangement in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
[ElectriciansForums.net] Earthing Arrangement
Hello,
Currently still studying at college. I seen this yesterday on a site. I asked the question but didn’t really get a good answer.
I think this is tns. I see 2 10 mm on the left going to water and gas, 1 10mm going to the board. But where is the cpc coming from to connect back, I don’t see any connection near the cut out.
Thank you
Curious Student
no worries pal basically a tn-c-s has the earth and neutral connected in the device head
a tn-s usually connects the earth to the in coming cable armouring to supply the earth and a tt you basically supply your own earth by putting in a rod and connecting your path to that.
check this page on here it will give you a better understanding of earthing systems and has pictures Domestic - Earthing Arrangements Explained + Photo's - https://www.electriciansforums.co.uk/threads/earthing-arrangements-explained-photos.59354/
Reply to Earthing Arrangement in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
