Earthing for an EV Charging Point | Page 2 | on ElectriciansForums
Discuss Earthing for an EV Charging Point in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Were talking about a steel structure with maybe piled steelwork and a foundation slab that has steel reinforcement, (which could also be tapped and connected to the buildings MET) what would you honestly expect to change?? The DNO's TN-S, TNC-S, PME earthing provisions are out of our control too. The only earthing system that would be under local control is a made electrode TT system....
I accept that, but my argument is that the steel work is probably going to provide a better resistance than I will achieve with a load of rods.
Well at the moment we don't have any idea as to values, construction method or any other hard data, secondly the services could change (not likely on a new build I agree), there is a formula that needs to be calculated to see what value the Ra is required to meet that particular exemption, it takes no account of existing steelwork or services that may or may not be present.
He is the man signing the paperwork to say it complies and which exemption he is using.
If you look there on that page at the bottom of point (i) it referrs to Annex 722 item A722.3, this is the bit we need to see I think.
true
[ElectriciansForums.net] Earthing for an EV Charging Point
That's the problem, we don't have any hard data on anything as yet....
So am I correct in my working of:
Im = 8A (Clamped round Neutral at cutout)
Uo = 230
IL1 = 8A
IL2 = 25A
IL3 = 8A
So, I am typing this in my calculator:
70 / (8 - (70/230) x (8 + 25 + 8))
Answer is: -3.72
So, going on the Note, it says unless it exceeds zero, you do not need an earth rod....
Reply to Earthing for an EV Charging Point in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
A week later, and another update. I had been looking at the app settings at home, and reading the MI, it seems the problem.... since last week...
As many as you want, or need as long as you time all of them to come on at different times. Otherwise as MDJ's answer.
