uksparks
Im is the max neutral current, so having just worked it out,i think its worked out at 91A, does this figure sound like a realistic figure? I don't really know what to expect here...
Discuss Earthing for an EV Charging Point in the Electric Vehicles Advice Forum area at ElectriciansForums.net
Your max IM I calculated at about 53 to 54 A taking into account adding a proposed further 60A load to one of the low loaded phases assuming say L1=8A,L2 =25A, L3=68A
That is just from the information you have given, your PME rod/s in this case would need to be about 3 ohms
This is only a quick and rough calc with using assumed values
How did you come to that? can you show me the calculation how you did it please, my one came out different...?
I cheated lol I used Tony's XL spreadsheet to calc the N current
Simon above did it long hand
I have an Excel spreadsheet as well. Wanted to show the way to calculate it though. Either way its the same answer
I have enough trouble posting on here normally with IE11 lol without trying to insert symbols lol
i did it this way and got a different figure...
Im=√((8-0.5(25+68))²+(0.866(25-68))²
I wonder if i am typing it wrong on the calculator?
Can someone else try this method please.
Reply to Earthing for an EV Charging Point in the Electric Vehicles Advice Forum area at ElectriciansForums.net
