T
The Tile Association
forum erroneous post removed
fair enough mate, the reason to separate the boxes is that the smaller box will hold all the brain PCB/CPU boards for an overall system. The CPCB boards just requires AC instead of DC that's how it comes from the manufacturer. It also comes within a smaller metal box from the manufacturer for additional security. The reason they are insulated from each other, so we don't have a situation of circulating current if there is ever a fault because the smaller metal box has a power supply unit which is also metal and is directly connected to the switchboard earth bar. The larger box has an earth bar which is also connected back to the MEB which is then connected back to the switchboard earth bar.I'm not up on Australian regulations, but I'm not understanding what you are trying to achieve in separating the AC and DC supplies in different containment, and why you suggest the boxes are insulated from each other, when they seem to both be earthed. Is this intended for EMC or electrical safety or something else? Or are we talking really high current?
Having two independent supplies into the cabinet, potentially from different isolators, could create a hazard for maintenance/ servicing etc. Is there a reason for not combining them into one feed?
Apologies for answering your question with other questions, but trying to understand the concept.
