View the thread, titled "IR External Car Park lighting" which is posted in UK Electrical Forum on Electricians Forums.
Cheers, a report been submitted to the Client & suggests improvement, with the first option to disconnect all Light Columns & hopefully IR measurements will improve.
Ok good luck with that Cliffed, but I perhaps misread or assumed the columns had been disconnected and like others assumed it was maybe a cable fault/low IR but now it could equally be within the column or one or more of the actual light fitting(s)?
As above. I assumed the cable had been isolated, and the poor readings were from that alone.
I almost expect to find less than perfect IR readings from any outdoor lamp fitting that has been in use for some time.
The cable had been isolated & IR tests were performed & measurements were poor throughout.
Within the time we were on site it became clear that this was not a simple fix, & we were actually concerned that we may even make the situation worse, disconnecting & then reconnecting.
There’s approx 30 columns & access is not great, hopefully the Client will go with a complete disconnection & see where we go from there.
Cheers for your input everyone
Reply to the thread, titled "IR External Car Park lighting" which is posted in UK Electrical Forum on Electricians Forums.
spraystone UK,
cliffed,
