Earthing of a conduit | Page 2 | on ElectriciansForums
Discuss Earthing of a conduit in the UK Electrical Forum area at ElectriciansForums.net
London
Hi there I work in a shopping centre and the tills are supplied by a chrome pole ( non standard ) that comes from a metal burgess ceiling . Inside the pole is a 2.5mm 3 core flex and a CAT6 cable (non screened ) that supplies the till . This pole does not have any earth . I’m now being asked to use an earth clamp to connect the pole to a piece of trunking above the ceiling via a 4mm cable . Question 1 is this necessary? Question 2 should the earth from clamp be connected to the same earth that is contained in this pole ? And question 3 should the CAT6 cable be installed in same containment as the power supply ?
That is an issue of good workpersonship.
God, give me strength. PC gone mad.
You'll probably find that workpersonship is now verboten in favour of a term more inclusive of those that identify as unicorns.
PC is now not enough for the progressives, you'll have a trawl through the Guardian and find the latest approved term.
Is there a proprietary system for this ?
I know there is power poles and posts but this is basically a piece of containment or pipe
In theory it may not need earthing if a double insulated cable and grommets/bushings are used
But the above is ideal circumstances, it may be hazardous as described without the link to the steel trunking
youcan't mention unicorns without mentioning unifannys.@ Ill get my coat.
Reply to Earthing of a conduit in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Recommended Sponsor News
Hi everyone,
