ECIR requested by the supplier. | Page 2 | on ElectriciansForums
Discuss ECIR requested by the supplier. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I disagree. There is a box especially for detailing what the condition report is for. Put in there “to determine dead installation is safe to be made live by the DNO”.
This then spells out clearly what the report is for and would make it clear why the excessive limitations.
It would aslo make sure the report could not be misused by the owner.
If you look at the notes for EICRs on the model forms, it clearly states the report is to confirm where reasonably practicable that the installation is in a satisfactory condition for continued service.
If this inspection is to be conducted in accordance with BS7671, the very first thing to be done is to visually inspect the condition of all electrical equipment which is not concealed.
God forbid that after failing to spend 10/15 mins looking round the place and you sign off the installation as being safe to energise, that someone is electrocuted due to bare conductors hanging out of a wall or ceiling, or exposed by a broken socket front plate.
Seriously, are you not going to walk around and count points served, or confirm circuits?
Of course you would. In order to complete dead test you would dommost of that anyway.
Is that what is being debated?
Seen it a few times before, usually goes like this.
Letter received from DNO
"Dead testing MUST be completed and a copy of the test results MUST be made available for the engineer on the day of connection otherwise connection cannot proceed"
Day of connection, to DNO engineer
"Hi mate, got your test results you need"
"My what ?, nah mate I don't need any of that. Where's the head going ?"
So the report is done and let's say that a C2 is found. Would DNO refuse to connect? Assume C3 is ok to connect and C1 not ok. Just wondering :)
You could do a EICR dead using R1R2 and IR (where possible), any circuits not passing muster could be left disconnected with the prior agreement of the client (you could make this a condition of the works)
Worst case - they could be left with a install with adequate bonding and 90% of the circuits not connected :D
From past experience- if it is not connected they deal with it sooner rather than later
Reply to ECIR requested by the supplier. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
