economy 7 rcd test | Page 2 | on ElectriciansForums
Discuss economy 7 rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
good point well put! Sorry I miss read the post. . . . Doh!
if your gonna feed the off peak board from the peak board be careful as some installs use a different phase for off peak to on peak. have you thought about taking the rcd out and testing it? if you only want to test trip times
perhaps I'm missing the plot here. but isnt the point to test the rcd in its final lcation to prove its functionality in the installation?
Reply to economy 7 rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, guys for explaining why I get the strange readings without using three prongs. I want to say I tested with my TIS 849 as well, but I'm not...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
