Discuss economy 7 rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
on the meter side of the do you mean? dunno? I'm not down there for a couple days now, so will look then.is there an override on the timeclock?
mmmmmm. . . . . . me thinks this is the power board side of things, therefore not possible.or maybe alter the times, then return to normal!
phase blocks? do you mean henly blocks? also not p[ossible as there are none in and the supplies are in the ground floor garage whilst the flat is on the 3rd floor.you could temp feed it via some phase blocks??
Reply to economy 7 rcd test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
