EICR audits _________ | Page 4 | on ElectriciansForums
Discuss EICR audits _________ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Let us not forget that the people who dreamed up this lot in the original design of things heartily recommended fuses on the Line and Neutral. Ever since I encountered these and knew who commanded it to be I thought mhmmm, I must really watch what these people say and check if it makes sense.
Is there a little badge somewhere to tag my earlier posts as "ironic"?
My point was that, yes, ceiling roses and BC/ES lampholders are exempt at the moment, but someday they may be superceded by a product that doesn't need to be exempt and is safe by design.
Oh... there we go again.... its a lamp-holder, not a bulb-holder
florence nightingale had a lamp. it didn't have a bulb though.it had a wick.
Agreed. But you are ussuming they have been switched off.
I never Assume anything :) , I was just saying that some DBs and CUs do not all have exposed bus bars , anyway that's beside the point the enclosure still has to be to the correct IP ratting, so blanks will be required if there is a live bus bar or not
But this is also besides the point, as the CU's did have blanks. They were just plastic..
Sorry yes forgot how this thread started. , So in answer to that I would not code plastic blanks, unless they were loose and fell out easily , as I said before you normally need a screw driver to prize them out , If its a new amendment 3 board the front flat is the fire barrier , so no need for metal blanks .
Reply to EICR audits _________ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
