EICR coding................ | Page 3 | on ElectriciansForums
Discuss EICR coding................ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think we have come to the conclusion it is not a C2. How big is this house that you envisage it will be at the other end of? As has been said, we are talking about a boiler, on it's own circuit, in 1mm protected by a 6A OCPD and then a 3A fuse. How can it be dangerous (C2)?
i might be inclined to give that a C3. my reasoning there is that a fault on the bouiler is more likely to trip the 6A MCB rather than the 3A fuse. ( i.e. no discrimination). tin hat fixed in place.
There is a 3A fuse in the boiler FCU, forgot to mention that. Not sure I would code on discrimination though unless a whole installation was likely to disconnect.
I would say the 1.0 cord size is not relevant in that case.
Reply to EICR coding................ in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
