EICR on a Sunday | Page 3 | on ElectriciansForums
Discuss EICR on a Sunday in the UK Electrical Forum area at ElectriciansForums.net
L
Lewis85
Working Sunday's suck! Let alone doing condition report for someone that thinks your waiting to find faults and rip them off! People out of the trade just don't get it do they! You point out things that are unsafe/dangerous and they look at you like it should be rectified in the price?? I'm beginning to think they ain't worth the hassle. Done a full test on the property took off around 90% of fronts and then crawled around in a ****ty loft! Didn't even get a cup of tea!!
Does anyone avoid these?? This year I'm hoping to get some work with the local estate agent (they seem keen) but after this ball ache I think I'm going to regret it as this is something they will want doing a lot.
I fitted 3 lengths of 2.5mm butyl flex to immersion heaters yesterday. I'll let myself off over sizing the cable though as they were 4kW elements. Now that would have been pushing 1.5mm flex to its limit, but a 3kW element certainly wouldn't.
I don't see how you can consider that to be running it close? It is only 4/5 of the rated current of the cable
Indeed. For anyone worried about using a cable near rating, remember that the heat dissipated is proportional to the square of the current, in this case 16/25 or about 64% of the permitted temperature rise.
I can see the point in standardising on 2.5 for 3kW aircon loads though as the voltage drop during compressor starting is critical and might often be a more onerous requirement than CCC.
Please can you explain this one to me as I've not heard / been taught this calculation / consideration .... sorry if I'm being dumb!
p.s.Can we not just say heat resistant flex rather than butyl ... its so much easier to spell!!:tounge_smile:
Butyl has enhanced heat resistance over standard duty flex, but not all heat resistant flex is butyl. Butyl is rubber HR flex but you can get PVC HR flex too.
Cheers.
I now need to learn to spell butyl correctly then! Lol! Only every used "heat resistant flex" from wholesalers. I'll have a look into when butyl would be prudent in comparison to heat res. flex.
I didn't notice the link between P = I2 x R, so thanks for clarifying for me
Reply to EICR on a Sunday in the UK Electrical Forum area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
