EICR
DB has redundant cables connected to protective devices!
Any reg in the 18th??? Memory recalls (badly) something in GN4
Discuss EICR Redundant cables in DB, MCB taped over! in the UK Electrical Forum area at ElectriciansForums.net
Yes your right Chris.I’m so confused here. If they have been taped off for 2 years. Why not just disconnect them and stick them into to earth bar whilst on site, literally 1 minute per circuit. You have spent more time searching a reg number than it would have taken to just sort it on site. I wouldn’t even charge, you would disconnect the bloody cable to R1R2 anyway? ??
Fair enough, I was just trying to stop it descending into back and forth name-calling and frustration ?
Shouldn't worry I get that feeling 24/7.Yes your right Chris.
I feel so stupid now.
Thank you for a very good non abusive answer.I think one of the things that strikes me here is that the OP, has gone about his EICR in the wrong order. If I am on a site where, as the OP states, there is no certs, charts etc. I would prior to the EICR spend time familiarising and charting the circuits and breakers. I would be advising the client of this and making clear the costs. For instance the taped over circuits/MCB, who knows if the MCB works or polarity is correct and therefore the cable safe? Without investigation it would breach EAWR in that you may be exposing yourself and others to danger by just plunging in without knowing the installation prior to poking about.
Reply to EICR Redundant cables in DB, MCB taped over! in the UK Electrical Forum area at ElectriciansForums.net
