EICR Test Fail, before and after | Page 3 | on ElectriciansForums
Discuss EICR Test Fail, before and after in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, recently had an EICR test done by 'Landlord Certificates' which failed due to circuite 3 having two radial circuits into a single 32amp MCB, they advised splitting it into two 20amp MCB's and quoted Ā£174 including EICR certificate. The Electrian appears to have simply taken out the 32amp MCB's and put in a 20amp and 16amp. Was the original actually a fail? And is what the Electrician has done now acceptable?
[ElectriciansForums.net] EICR Test Fail, before and after
Is circuit 3 a ring ? Or is it already a pair of radials ?
Is the feed to the boiler via a fcu ?
What type of boiler is it ?
Do you have an immersion tank heater ?
The chap who come to do the EICR said 3 was a ring that had lost continuity, but I don't think he can be relied upon.
Yes Boiler has FCU.
Combi boiler - no tank, it was fitted last year by BG
Sorry not much to add except to say those terminations are so bad they make my eyes bleed. Exposed copper all over the place.
I think you need a new electrician that comes recommended. If you don't know any from family or friends then at least you could look up NICEIC etc for a registered electrician from your area.
Reply to EICR Test Fail, before and after in the UK Electrical Forum area at ElectriciansForums.net
There is one reason to have an inspection every three years instead of the five. Itā€™s more work and money for them šŸ˜šŸ˜
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
