EICR's after 1st Jan 2019 .... | on ElectriciansForums
Discuss EICR's after 1st Jan 2019 .... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So you are doing an EICR next year and you are inspecting a consumer unit with these 2 "makes" of RCBO's in it ...
[ElectriciansForums.net] EICR's after 1st Jan 2019 ....
So is it:
As from experience and manufacturers, direct information both the RCBO's are identical except for the printed livery on the casing so no code if it was a Hager and Wylex I would tend to say C3 improvement recommended especially if the incorrect RCBO was easily still purchasable.
The manufacturers of those two RCBOs have made a conscious attempt to differentiate them selves from each other by branding them differently.
It's not for the end user, installer or even inspector to jump to the conclusion that just because both manufacturers have used the same style of casing, which may well be made by the same manufacturer, that the product inside is exactly the same - I think I would struggle to form a decent court-worthy argument that the reg relates to the manufacturer of the casing and because they look similar the different brands can be ignored.
Substituting a product which looks similar but carries a less well known brand is almost always done for financial reasons and I think a judge or jury would be likely to pick up on that.
C3.
C3.
Same manufacturer in the op picture but I agree with your comments regarding different brands used
Reply to EICR's after 1st Jan 2019 .... in the UK Electrical Forum area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
For the OP in case they have not come across them so far, the free BPG can be found here...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
