Can a single phase single speed 1.5hp induction motor run on both 50 and 60 hz 115 volts
Discuss Electric ac induction motor 50hz to 60hz? in the UK Electrical Forum area at ElectriciansForums.net
Yes look for single to single.Thanks Fazz711
Unfortunately it doesn't ship to usa however I found a similar one but it says "The input for this VFD is 1 or 3 phase, and the output is 3 phase. Should I be looking for one with Single phase output not 3 phase
That would be the way I would do it.I have never come across a decent single phase to single phase speed controller
if I was doing it, I would be Looking for a 3 phase motor and a single phase to 3 phase inverter
I could then buy a decent quality system and not have to worry about the effects of capacitors and how they interact with a vfd drive.
No don't think so as the unit will see an imbalance and shut downForgive me if i butcher this but if the input voltage is 220 volts 50Hz and the output is 3 phase, im assuming the output voltage is 220 volts across phases and 60Hz. Could i not then feed the motor from 2 of the phases
Reply to Electric ac induction motor 50hz to 60hz? in the UK Electrical Forum area at ElectriciansForums.net
