Electric Cooker | on ElectriciansForums
Guest viewing is limited
Discuss Electric Cooker in the DIY Electrical Advice area at ElectriciansForums.net
Mg12345
Ealing
Good Morning all
Looking for some advice.
Recently had an electric cooker installed from a company found on check a trade.
Before engineer arrived he advised me to buy a 2.5mm cable to connect to the mains. When purchasing the shopkeeper informed me that cookers usually would need a 6mm cable but the electrician insisted that 2.5mm was sufficient and came and installed it.
I’ve had further advice that this may not be good enough.
Hotpoint were unhelpful and said it would need to be decided by an electrician, they would only tell me the cooker will run on max 35.2A
Model no: HS67V5KHX
Any advice appreciated.
Mike.
Reply to Electric Cooker in the DIY Electrical Advice area at ElectriciansForums.net
I have replaced the back box for a 35mm one, and it all has refitted more comfortably. I'll get the electrician to check it out when fitting the...
Your oven is 3950 watts, oven plus grill. The quote you have posted is probably for a UK installation where the 13amp plug is fused, unlike...
Recommended Sponsor News
Hi everyone,
