Electric gates | on ElectriciansForums
Discuss Electric gates in the UK Electrical Forum area at ElectriciansForums.net
keniff
east sussex
Anyone on here install electric gates? I could do with a bit of info if anyone has time could you pm me, cheers guys
What sort of power are the motors on a double swing open gate, I know they vary alot but just a rough guide would be good to know, also on the communication side of things is it just a cat 5 from phone to gate control box ? It's a drive way about a car and a half wide, Thanks guys
are you talking about the leaf weight they can open etc or the actual ratings for cable sizing ?
as for the gate controls they pretty much just need a n/o relay from an intercom or ocker s/w.. there are settings on the board as to whether it would open/close or open/stop/close/stop if that helps?
so would i need a cat 5 or something else from house? i have in my head a 230v supply to the gates and a swa cat 5 from house to gates for intercom/gate opener from house? would this be sufficient
most acces companies now do a gsm system for gates no wiring involved there is a company called nice do a 24v remote gate openig system the battery is powered by a small solar panel never fitted one but the idea sounds good.
Reply to Electric gates in the UK Electrical Forum area at ElectriciansForums.net
This EV 10/16mm 3 core ultra cable sounds good to run it in the front. I ran 3x CAT5 armoured cables at the back. The existing 10mm cable goes...
They think the supplied one might be too small for their needs, or it's a Wok type thing that they think mightn't be supplied at all (they would...
