Electrical descriptions and phrases ...... | Page 2 | on ElectriciansForums
Discuss Electrical descriptions and phrases ...... in the UK Electrical Forum area at ElectriciansForums.net
imago
Nearly Esteemed
Birmingham
... that are inaccurate or make you laugh.
One of the DNO guys came out with "air insulated" the other day, and it made me think how daft and inaccurate it was. Two bare overhead cables not touching air insulated my 4rse!
It set me thinking that some of the accepted descriptions aren't really that descriptive. Consumer unit for example doesn't provide much information on what it is or does. I'm not keen on main switch, as if it's the first in line surely it should be master switch?
and yes, I have had far too much time on my hands working alone in Wales. :thinking:
All true if you refer to a controlled/constant dry state 'air' rather than atmospheric air which (especially in Wales) has varying levels of humidity not to mention running water. So if you go for gas separation within a sealed vessel then fine it can apply.
But air insulation to describe two exposed conductors dangling between poles is patently inaccurate nonsense.
Then what substance would you say provides the insulation between them?
An Americanism "raceway" WTFs that
But is 'trunking' really a more descriptive name for it?
With 100% humidity air still falls into the insulation bracket I merely used the dry air as a simple example to express it is an insulator now yes agree it varies with temp' and humidity but so does every other insulator and conductor hence correction factors exist... sorry to disagree here but just because its insulation value has variation between 2 known values does not make it inaccurate nonsense. If you only point of argument against this been an insulator is because it doesn't maintain a set value then you can say the same for conductance of a material ... we take it at either room temp or the rating of the insulator 70.c commonly but have to correct the value if needed ... the same is done with air when designing exposed overhead systems.
As has been asked, ''what substance would you say provides the insulation between them?''
It's a totally relevant term, air has been used as a means of electrical insulation from the very earliest days of electrical transmission. Can't think of any other means of suitable insulation when transmitting say 400 KV and above, over long distances...
what about the PVC insulation on your bit of T&E? that only insulates under specified conditions, increase the voltage and it will soon cease to insulate, whereas that damp air will still be insulating at that voltage!
Not really a definition issue so much as a spelling one, but the one that gets on my t1ts is contactor/contractor!!
I remember being shown around a switch room in one of our buildings in Washington DC and the conduit runs were really something, I mentioned this to this septic sparky, his reply was epic " conduit, that ain't goddam conduit that's m--er feaking raceway hence the refference
Reply to Electrical descriptions and phrases ...... in the UK Electrical Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
