M
Markymark981
Hi
just completing a rewrie for a customer and they have asked about electrical heating in house rather than a gas central heating system...there would potentially be a total of 14 x 2kw radiators, I was thinking about is it acceptable to run 3 additional ring mains just for the heating system or even run it in 4mm cable rather than 2.5 t+e, no sure as never been asked for electric rads before and I know that many cannot be installed on the normal ring that general stuff is plugged into so wondered if anyone could point me in the right direction?
Requirements are
Top floor
2 x 2kw rads
middle floor
6 x 2kw rads
ground
6 x 2kw rads
Thanks in advance chaps
There aren't many reasons to choose electric heating over gas when a gas powered system already exists. Why do they want to swap?
Hi
Requirements are
Top floor
2 x 2kw rads ...... 2.5mm radial
middle floor
6 x 2kw rads....... 2 x 4.0mm radials ( 3 on each )
ground
6 x 2kw rads......2 x 4.0mm radials ( 3 on each )
in red the most cost effective way.
It's a student let vacant at the mo and they need a brand new gas system installing if they chose that option :)
well, without applying diversity, those heaters are over 100A, so i'd call it a non-starter.
Is there gas to the building? If there is no gas then a electric boiler, wet central heating system and hot water cylinder plumbed as an s/y plan would be the best option IMO.
Electrical heating
Markymark981,
Leesparkykent,
TrueNAS JBOD Storage Server
