Electrical Project - Advice Needed | Page 2 | on ElectriciansForums
Discuss Electrical Project - Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
R
ryan_93
Hi Guys,
Im after a bit of advice on a project that i am currently working on.
Basically i have a motor powered by a 12v battery which turns a shaft through a gearbox.
What i want to do is use an alternator, generator or something similar which is also attached to the shaft via a gearbox to charge the 12v battery.
Is this possible? Can i simply use another 12v powered motor and switch the polarity around to use it as a generator?
Thanks in advance,
Ryan
There are way's to have the battery continually being charged, but it would involve a suitable in-line charging unit being used across the battery. So you would need a source of power to supply the said charging unit...
Reply to Electrical Project - Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
AVR's and Generators in a rack??? And only at 7.5kW?? What are you actually trying to build?
