Electrical water heater problem | Page 2 | on ElectriciansForums
Discuss Electrical water heater problem in the UK Electrical Forum area at ElectriciansForums.net
France
Good morning everyone,
May I ask your advice please. I have an electrical water heater that was renewed last year. This water heater is only used occasionally during the summer. It heats the water in our guest room over our garage. The water in the heater heats up but the cut out is tripped during the night.
I have checked the wiring according to the diagram supplied with the heater. All correct. I have replaced the master cut out 40 amp switch. I have just replaced the 25 amp off/auto/on switch. The cut out still trips during the night.
Any suggestions or help would be much appreciated.
The water heater is in a separate building with it's own consumer board. When the cut out operates it trips the supply in that building, not the supply in the house.
I take on board the comment that the thermostat might be set too high, so I have reset that to a lower temperature. I will check tomorrow morning to see if it has tripped again.
In the mean time I will up load a picture of the cut out and heater off/auto/on switch.
As you have gathered, electrical problem are not my thing. Photographic or vintage car restoration yes, water heaters NO.
Thanks again for replying.
P.S. I am trying to find somewhere to poke the Garlic!
[ElectriciansForums.net] Electrical water heater problem
Who said it is over heating.
No one said it's overheating, we have not been informed as to what is tripping, assumptions have been made that it could be the overheat trip. Until the OP comes back and tells us which device is tripping we are all shooting in the dark. The OP has no electrical qualifications by the looks of it, so it is likely he is getting confused, and transmitting that confusion in his post, not his fault, but it does make it difficult to glean the right information.
Reply to Electrical water heater problem in the UK Electrical Forum area at ElectriciansForums.net
There's some stunning Chinglish on that data plate
    • Optimistic
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
