View the thread, titled "ELI at pendant..using long lead" which is posted in Australia on Electricians Forums.
C
claire_r
Hey all, quick question for you.
Did an earth loop at a socket, got 20 ohms which is acceptable as it's on an rcd.
Did another earth loop on a soft test at a light fitting using a long lead l/n at socket and connected to earth at light. The lighting circuit not being on an rcd.
Got 20 ohms again?
Am I reading through the socket circuit by using this method? I would presume I'm testing the earth at the light back to the board and so on but I'm confused as to how I got the exact same reading? This reading not being acceptable if it's not on a rcd.
Any ideas welcome, thanks :)
The main reason i haven't bought them, is that i not yet got into a situation where i've thought 'i wish there was some gadget that would make this easier'.
Thats the trouble with you young'uns. Always want the easy way!
:D
I like coffee, I'm gettin some....:D
ffffffff
Yeah, I've made my own adaptors for "kliks" and the like, just put a single socket in the other end of the plug flex.
even better.
the kit looks good though---dunno about the 55 quid mind.
There are so many variations though,that aren't covered,such as those gu 10's that only take cfls(sgu10 i think they're called),Ges,pl etc.
One of the meters I had been using a little while back had a adapter on the earth probe that you could plug in your N probe,which gave you a spare hand to hold onto your steps.Your test is between phase and earth.
(croc clip on earth)
lol well thanks all for suggestions....hmm i might have to have a looky into the plug in adapters...make my life alot easier as yet again today.....eli at a pendant....did it the old fashioned way though....wish i had pointier elbows to press the test button hehe.
Reply to the thread, titled "ELI at pendant..using long lead" which is posted in Australia on Electricians Forums.
