Em Lighting key switches! | Page 3 | on ElectriciansForums
Discuss Em Lighting key switches! in the Australia area at ElectriciansForums.net
C
Crosswire
OK,
Settle this once and for all please chaps.
When keying off emergency lights, should you switch;
1) just one pole (e.g. the permanent live)
2) two poles ( e.g. both switched and permanent lives)
or
3) three poles ( both lives and neutral also (as some key switches have two poles) ) ?
Is here is a mesage here :D
Reply to Em Lighting key switches! in the Australia area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
