Emergency key switch wiring | Page 3 | on ElectriciansForums
Discuss Emergency key switch wiring in the UK Electrical Forum area at ElectriciansForums.net
dave19
Hi Guys,
Can you help ? I just wanted to know how you wire a key switch and normal switch together. Is this how it should be :-
Feed from board to common on key switch
power to emergency lights comes off the load side of key switch
loop feed comes off the common side of key switch to common side of normal switch then
power to normal lights comes off load side to normal switch.
Is this it and if not is there a different way of doing it. Please explain in as simple terms as you can. Diagrams would also help ? Thanks guys.
Dave.
so you went back a full topics page just to look for a thread just to have the last word in ?
lol.
No Biff I'm not "trying to have the last word" and I never was - you made that up yourself. What I'm doing is participating in an electrical discussion which is why I come on this forum, unlike yourself who only seems to come here to be a pain in the backside.
I've seen it both ways as the rest of yous, council offices have non maintained so normal lighting stays on and preventive maintenance is what happens in these buildings I.e change lamps if discoloured clean fittings if boggin, then other places have emergency light built in and all lights go out, can honestly say lux levels only matter at design stage. From what I've seen. But maybe you have seen different and lux levels matter. Troll 1 Adam 0
And to know what lux levels are required and how to achieve them requires relux, and knowing the photometrics of the unit you are installing the area size you need to cover so relux can tell u were to position em light units.
Or like most of us place over exits, change of floor level and direction and put a few extras in long corridors or large office spaces.
Why do you think you do preventative maintenance if, as you say, lux levels don't matter once the circuit has been designed?
This is like saying you don't need to do any testing on any circuits because it's been designed correctly, or more likely used the pre-designed off-the-shelf circuits out of the onsite guide.
Reply to Emergency key switch wiring in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
