Emergency key switch wiring | Page 4 | on ElectriciansForums
Discuss Emergency key switch wiring in the UK Electrical Forum area at ElectriciansForums.net
dave19
Hi Guys,
Can you help ? I just wanted to know how you wire a key switch and normal switch together. Is this how it should be :-
Feed from board to common on key switch
power to emergency lights comes off the load side of key switch
loop feed comes off the common side of key switch to common side of normal switch then
power to normal lights comes off load side to normal switch.
Is this it and if not is there a different way of doing it. Please explain in as simple terms as you can. Diagrams would also help ? Thanks guys.
Dave.
Well I have (seen a lux meter used) several times as it happens, on a major job before hand over for the clients rep to witness if memory serves me correctly.
during the initial verification prior to completion to ensure the designers lighting criteria has been met , yes ?
but for every subsequent routine test thereafter ?
no point.
That would be after the design stage.
no point.
Maybe not "every subsequent routing test thereafter" but that doesn't alter the fact that the use of a lux meter can help detect when emergency lights no longer emit the required lux level.
Neither have I, but it's not to say you can't or shouldn't use one.
so for the last 24hrs you have been arguing in defence of a particular method of wiring a keyswitch for the purpose of carrying out a lux test that you nor i have ever seen been done during routine maintenance ?
good grief.
Quite amusing how this topic has gone from how to wire em lights, to know testing lux levels when doing maintenance.
To be honest the only places that will check them are either council, police cells an a few big companies, most maint engs see them working in em mode and couldn't give a rats arse about lux or wouldnt know we're to find a lux meter if they got asked.
good grief.
No that wasn't my initial reason for defending it, and I didn't favour one method over the other. What I said was wiring it in that way would facilitate the use of a lux meter to check the emergency lights are emitting the required light level.
Why do you think I should be against something just because I've never seen it being done?
is it a requirement under the BS5266 Emergency Lighting code of practice to carry out lux tests during routine testing ?
not that i can find.
Are you trying to tell me BS5266 makes no reference to lux levels?
I'm fairly certain it does, and a good way to ensure compliance with that is with the use of a lux meter, not that there's any specific requirement to, but then there's no specific requirement for PAT testing but businesses still pay to get it done.
Reply to Emergency key switch wiring in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
