Emergency light wiring | Page 2 | on ElectriciansForums
Discuss Emergency light wiring in the UK Electrical Forum area at ElectriciansForums.net
Minnions
Um I've wired an emergency light up but I can't get it to work the way I envisaged it would. I would like the light to switch on and off from a light switch when powered like any other light. When not powered I would like it to illuminate using the battery etc. Now it says in the destructions that for non-maintained remove the link. So I removed the link and it doesnt really work how I thought it would. When I switch the light switch on it turns off goes to green light. When I turn the light switch off the light illuminates. When power is switched off it seems the battery does come on so that part is working. Am I making sense. Heres a picture of the inside of the light. It does not mention s1 or s2 in the manual. Any ideas what I've done wrong? thanks
[ElectriciansForums.net] Emergency light wiring
Ive just seen your link i missed it earlier .... yes permanent power to the marked terminals and have your switch connected across the S1 and S2 ....give 24hrs to charge as you have drained the battery ....
So switch live to S1 then add a little tiny link of cable from S1 to S2... ok I will give it a go and let you all know. I'm sure you can't wait!
You better be winding me up.
L - N - E is your permanent supply. The PCB provides voltage to S1. If voltage is introduced to S2 the lamp lights, hence why it is lit with the link in place. If you take a wire from S1 to a switch then back to S2 then you control when the lamp lights via the switch.
nooooooo!!!!. do not put a neutral into S2.
Yea after posting I did think that this probably wouldnt be the best idea.
So...
darkwood said:
just put the twin cable from the switch dont connect anything else to it except to terminals S1 and S2
Right ok so I dont need to put anything in L N E terminals... so the twin cable supplying the light I have the live from that cable in a choc box with the live from the switch cable. I have the neutral from the supply cable in the N terminal of the fitting and the switched live into the L terminal.
at the switch I have the L in the L terminal and the switched live in the L1 terminal
so no pcb embedded in my face unfortunately. and no I havent measured any resistance yet because Im still reading and typing it's much safer.
Reply to Emergency light wiring in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Recommended Sponsor News
Hi everyone,
