Emergency lighting help | on ElectriciansForums
Discuss Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
J
Jon West
Good afternoon,
yesterday we had a power cut in our care home, 2 emergency lights did not kick in. They kick in on the key flick test which i do every month but they do not kick in when i switch off the MCB in the consumer unit. We have just had new batteries put in and they are fully charged. The green led is on when the power is on. We do have a contract for maintenance with Lowe and Oliver but as maintenance manager if i can fix it it will save the call out fee. Any ideas why they would work on a flick test but not a full power cut?
Are they maintained fittings because you may have an issue will dual supplies from different circuits, if possible turn all the lighting breakers off.
Turn all the lighting breakers off and see what happens.
The power cut done that for me yesterday, thats how i spotted the issue. We had to switch the entire supply off to the home.
Reply to Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
It’s getting to the point where full LED replacement is cheaper than spending time on testing and possibly replacing parts.
