Emergency lighting help | Page 3 | on ElectriciansForums
Discuss Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
J
Jon West
Good afternoon,
yesterday we had a power cut in our care home, 2 emergency lights did not kick in. They kick in on the key flick test which i do every month but they do not kick in when i switch off the MCB in the consumer unit. We have just had new batteries put in and they are fully charged. The green led is on when the power is on. We do have a contract for maintenance with Lowe and Oliver but as maintenance manager if i can fix it it will save the call out fee. Any ideas why they would work on a flick test but not a full power cut?
Hmm. If the green LEDS stay on when the test switch is operated, the wiring is wrong as per Davesparks' suggestion but the fact the LED is on should indicate reliably that the battery is on charge, not merely that the PL is live. So although the test switch would not test the fitting in the intended manner, if the battery is good then the fitting should still function during power loss. If the green LEDs go off when the test switch is operated, then there's no evidence of a wiring error and again the fitting should still work.
I think we've gone as far as we can go with the evidence available and investigation with test equipment is now needed to make any useful progres...
Depending on where the board is they may illuminate for a short period then have failed by the time he gets there. He may only be flicking the test facility quickly but need more info and he seems to have gone.
Nope, i can see the lights from the consumer unit and watch the lights when i switch them off.
Which could just be the lamp obscuring the LED
The green led is illuminated and goes off when flick tested and mcb switched off.
Yes thanks everyone, our contractors are coming in Monday to take a look as they have done some work on the lights. I thought i would put it out there just in case there was an easy fix without me calling them.
Interesting post. As previously commented on by others. I'd be looking into the key switch possibly switching incorrectly perhaps the switch feed, strange that although the battery is charged it does not illuminate when power is cut.
I've previously seen like for like lamp changes cause electronic ballasts to become faulty on em lighting. They can be high maintenance sensitive bits of kit
Reply to Emergency lighting help in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
It’s getting to the point where full LED replacement is cheaper than spending time on testing and possibly replacing parts.
