emergency lighting | on ElectriciansForums
Discuss emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
F
farmerian
Got my hands on a emergency light today I wired it up, thinking it could come in handy when I have got to get in lofts, turned it on and the fluorescent tube blinks then go's off when I turn the power off the emergency light works perfect, could it be a faulty ballast ? I'm a qualified electrician
Sounds like a non maintained fitting to me, these dont light up when a supply is present, they just charge the battery, then once supply is lost hey presto they come on. Is there a green led lit up when your supply is connected?
Im guessing he's rigged it up with a socket on the end, which begs what MDJ said...why not use a headtorch :confused: makes zero sense.
And even if i was going to wire a light to help me see, i think an emergency fitting would be the last on my list. Got to a be troll thread.
Lol head torch means lots of battery's, I didn't think it a non maintained fitting as the tube lights up for a one second and as a switch wire in put marked up on the fitting, yes they is a l e d light in the fitting witch remains on
Reply to emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
BS 5266-1 Doing a lot of three hour drain. And when the lights fail or so bad they don't show much light (hight ceiling and it's a small LED...
Or a combined fitting in each row.
nicebutdim
N
