EMF dangers - advice needed | Page 3 | on ElectriciansForums
Discuss EMF dangers - advice needed in the UK Electrical Forum area at ElectriciansForums.net
London UK
My flat has high levels of EMF, Electromagnetic Field from floor wiring / Electric Field from ceiling wiring. It is often is above safe levels for continued exposure. Two years ago I had 2 incidents when EMF was so strong it made my entire body shake visibly - I had to run to get out of the flat.
I would like to know;
1) what could have been the cause of these two incidents?
2) what are the physical consequences of remaining in this situation for a sustained length of time when said incidents are occurring?
3) since the problem remains, what is the probability that these incidents could happen again - am I correct to be scared?
Can I ask, what repairs have you asked your landlord to carry out, and who has given advice to conclude what is needed?
I can't and won't comment on the sensitivity to em fields other than to say that there could be alternative (cheaper) ways of shielding using foil panels to create a faraday cage, which could be an easier remedy depending on construction. The OP could consider that.
Do any supermarkets connect their POS terminals with wifi? I would have thought they all used ethernet?
It's ambiguous because not everyone cares about the distinction and capitalisation, and many who discuss the significance of EMFs don't have much to do with emfs. You can usually discern the intended meaning:
'The emf from the thermocouple is very stable : Electromotive force.
'The EMF from the phone mast fried my giraffe ' : Electromagnetic field.
actually undergoing issues like this. Although there is a wealth of misinformation about EMF and it's effects of the human body, there is also a wealth of research done by medical experts and those from other scientific fields who have drawn direct correlations between health issues and this - please research it yourself before writing posts such as
It would be useful if you could cite some of them as I have not seen any showing this. Don't forget that we have been running an "experiment" over the last 20+ years subjecting over a billion people to significant EMF in the form of mobile phone use and to date very little evidence of ill effects have been demonstrated (excluding morons using one while driving and causing death & injury that way).
How does using a mobile phone effect you?
information especially from 'trusted' bodies. Don't forget, 'trusted' scientists once thought the earth was flat....!
Except they never did.
Both the Romans and Greeks knew the world was round, with Posidonius (135BC to 51BC) estimated the Earth's circumference at 39,000 km (only 1,074km too small).
By the time the "scientific method" was established (often with significant credit given to Francis Bacon (1561 to 1626) they had already seen Christopher Columbus' attempts to reach India going round the world in the opposite way in 1492 and encountering America by surprise (hence the West Indies naming).
Reply to EMF dangers - advice needed in the UK Electrical Forum area at ElectriciansForums.net
You need a galvanic isolator in the earth coming from the shore power. If using lithium batteries you will probably need a dc-dc charger to...
davesparks
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
