Good work , SolarCity !
I think this should be a sticky ?
I hope this will not offend but thought i would add a couple of notes as well ?
In Part 1a , where it asks for the grid reference . I found -
UK Grid Reference Finder to be very helpful at pinpointing the meter head , grid reference if you knew where it was located on a property .
Also in part 1a , where it asks for " Registered capacity (maximum active power export ) " , MAKE SURE you cross out the MW and substitute it for KW , as i forgot to do it on a 82 kw job and nearly missed the above 50kw tariff drop deadline over it !
Luckily my client was quite influential and i think the engineer processing the paper work thought better than to put a spanner in the works by not warning me ! If he had not it would have been moved to another department that handled the big boy applications and at that point early last year there was a potential one year wait for a answer .:rolleyes4:
Also don't forget to include all of your inverter speck sheets as these tell them a large amount of what they ask for anyway , just in case you have made a mistake with the data you have entered .
