enhanced protection | on ElectriciansForums
Discuss enhanced protection in the UK Electrical Forum area at ElectriciansForums.net
sima24
Hi, could someone tell me if rcd's are classed as enhanced protection? Thanks
additional protection is the correct term for an RCD (in that context).
Yes i have always took it as additional protection but on board schedule it asks if circuit is basic & fault protection, ticked yes for all as all circuits rcd protected but next to it has enhanced?
what 'board schedule' are you referring to?
i think he means the elecsa d/b schedule, according to the regs an example of enhanced protection is reinforced insulation
Reinforced insulation is classed as 'Basic and Fault protection'. Suggest you both have a read of GN3.
not being funny but dont need to read GN3 to tell me, just look in the BGB page 51, 410.3.2 note 2 it says, an example of an enhanced protective measure is reinforced insulation, on the elecsa d/b schedule it actually gives you 410.3.2 as a reference for it
waste of time asking me lol, i answered with what is states in the BGB which the actual elecsa d/b schedule sheet as a reference to for enhanced protection, but now being told i am wrong, so who is wrong elecsa and BGB or me for putting on here what it says, i can't win
look in BGB page 51 section 410.3.2 note 2, as i mentioned in the earlier post, if you have a look at the elecsa d/b schedule which you can down load of there site it as two rows of tick boxes 1 for basic & fault and 1 next to it for enhanced protection, it then actually says above these check boxes compliance with 410.3.2 which when you look it up in the BGB it says note 2 an example of enhanced protection is reinforced insulation i was only quoting what it says
[ElectriciansForums.net] enhanced protectioni think half the problem is elecsa's d/b schedule, if you see the attached image you will see you have 1 box for basic & fault and then 1 for enhanced, so if enhanced is basic and fault together there is no point in having a box for enhanced because you have already ticked the box for basic & fault
Reply to enhanced protection in the UK Electrical Forum area at ElectriciansForums.net
I seem to find two types of installation in older houses in which electric showers have been added: those with shower fed from an MCB without RCD...
nicebutdim
N
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
