Interested in opinions on this. Need to put the boiler (in my own house) in a temporary location for 6 months while an extension is built, when it will go in the extension. Running a dedicated 10mm to the temporary location will be a pita, and entirely unnecessary since I already have what, around 100mm CSA in the form of 2 X 22mm heating pipes running from the location of the MET to the boiler location, both individually bonded to the MET, soldered throughout, which I can locally bond to the gas main where it will come in to the house (at the temporary boiler location, through the wall).
Permitted under 543.2.6, however I'm not sure about clause (iii), not only for my own peace of mind as to compliance but also whether the gas engineer will be satisfied when he comes to fit the boiler (and how confidently I can say yes, it's definitely compliant).
Since the installation is under my total control, and I have no intention of allowing anyone else to work unsupervised in the house on water or any other service, does this clause mandate marking the pipes as earths throughout for instance? What constitutes a precaution against its removal in such a situation? Bearing in mind marking the entire length will involve lifting floorboards and be a similar pita to running a dedicated earth.
Tia, Pete
Tia, Pete
