European to UK plug conversion. 2-pin to 3-pin | Page 2 | on ElectriciansForums
Discuss European to UK plug conversion. 2-pin to 3-pin in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
^^^ what he said. And what I also said earlier if you care to read the whole post.
Thanks Phil - thats what I thought but wanted to check - so just wire it up like any normal UK plug - if you still have problems someone on here will be happy to do it for you!
Sorry Rockingit - didn't read your full post - that will teach me!
Yeah pm,d him asking for location if he,d have been near me would have done it for him but no reply!
Phil - doesn't need a sparky to change a plug top! There once was a time, not that long ago, when everyone could do it. In fact, my 14yr old daughter got a lesson on how to wire a plug in school recently (that I felt duty bound to pick a few holes in, of course!).
Phil - doesn't need a sparky to change a plug top! There once was a time, not that long ago, when everyone could do it. In fact, my 14yr old daughter got a lesson on how to wire a plug in school not recently (that I felt duty bound to pick a few holes in, of course!).
Yes I know, just thought I would offer to help him out foc if he was unsure,I know a plug tops a simple thing but some people still make mistakes.
Thank you all for your replies. Just to cover some of your questions
Before I bought the lights I checked with the company whether they would be okay to use in the UK and they said "The lights will work in the UK but you will need to change the plugs or use an adapter", which brings me to asking how to rewire them to a UK plug.
I did hope they would be "kettle leads" as that would mean I'd simply have to change them for UK 3-pin ones, but the lead goes inside the housing of the light so this isn't the case.
I have rewired plugs before, I've just never converted 2-pin to 3-pin before (and didn't know if you can) and there doesn't seem to be much about it on the internet so I wanted some professional advice.
Please see the attached photos
The photo shows this as being a French plug top, not the German Shuko which has a scrapping earth. The French system has a protruding earth pin at the socket outlet that enters the plug top as it's inserted into the outlet. Also the German plug tops are NOT polarised, the French plug tops Are. (but can still be used in a German outlet in an unpolarised form) !! ...lol!!!
Just cut the French plug off and replace with the UK, using Rockingit's sketch if your unsure how!!!
I'd said Schuko as a guess before I'd seen the pic, in my defence! It was a good enough bet.
Not my sketch, something I pinched!
In reality, they are both Schuko's, the French have just added a means of polarising the Schuko. If you look, you can see the provision for the German scrapping earth on the French plug top in the photo above, so it can be used in either country...
You posted the sketch, so it's YOURS!! lol!!!!
Reply to European to UK plug conversion. 2-pin to 3-pin in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
That will work fine as long as the Pirs use relay switching, some don't.
