Guest viewing is limited
View the thread, titled "everynights a 17th edition night" which is posted in Australia on Electricians Forums.
so does that mean if is 2.5mm it has to be in conduit or trunking ..
Guess so, that's how I read it, but TBH I would think its a bit impractical in real terms. You would have to run your trunking out into the flower bed etc right up to the earth electrode. Easier to use a length of sheathed 16mm sq (if buried or not) and be done with it.
Is it acceptable to use a TNC-S (PME) type earthing system on a caravan site for a permanent building?
Is it acceptable to use a TNC-S (PME) type earthing system for earthing a static caravan (the chassis would need to be earthed for this)?
Reply to the thread, titled "everynights a 17th edition night" which is posted in Australia on Electricians Forums.
