Good. Sometimes, but often you won't find it in the index so you'll need to know which sections are applicablenot more than 2.75m from the ground reg 537.6.3, i find it easier by going to index at back, whats your thoughts
Good. Sometimes, but often you won't find it in the index so you'll need to know which sections are applicable![]()
Minimum CSA for earth conductor on a TT supply............
I found when taking my 17th and indeed doing the revision questions leading up to it that you could generally pick a key word in the question that you then find in the index...........
i know in my head it is 6mm but cant find it in regs.. im @ 542.1.6
feel as if years away of knowing the sections.... index slightly easier, but are they all there... 17th exam in 2 weeks
Table 54.1...........
What is the maximum Zs for a circuit protected by a 30A BS3036 Fuse?
