Exploding bricks | Page 2 | on ElectriciansForums
Discuss Exploding bricks in the UK Electrical Forum area at ElectriciansForums.net
Derbyshire
Hi,
I work in the Domestic market and get frustrated when sinking back boxes using an SDS. Every now and then I come across a house where the bricks explode/shatter when touched with an sds chisel. My solution so far has been to chain drill and remove with a scutch chisel, but its really time consuming. Does anyone have another solution. Someone suggested filling the hole with adhesive and gluing the back box in.
Cheers
Chris
pva on the crumbly bricks, wait 2 hours let it bond up, then mix some bonding with cement (5 parts to one or something), glue the back box in the hole, next day when it hardens fix with some wall plugs.
I got some old bricks I can lend you, but they're propping up the Ford Escort in the front garden at the moment.
don't look at me. just because i'm a scouser, i ain't nicked your wheels. :eek:
be less aggressive ?????????????
Yep, I agree with the above a bit. However, to the OP I do know what you mean, and SDS drills can be a bit brutal. I find if the brick starts breaking up trying to fit a 25mm box, then I go more gently at it to try and get a deeper box in.
If the brick is completely knacked I normally opt for sand cement. I do like the sound of using rapid set though.
Reply to Exploding bricks in the UK Electrical Forum area at ElectriciansForums.net
