Can hear the click of the yanks safety catches being taken off as we speak.
Thank you all for giving comments, as I said I am not a new installer of electrical systems. But In explosion proof systems, I am a little new, I am learning right now but not installing. I preparing myself for such a situation.
Therefore I am requesting you about the cable.
Where I am considering the location is an open area with a shed.
I am just wondering of cable that it should be heat proof or heat retardant.
This is the question?
If I am going to install conduits then me should Install heat retardant or heat proof cable.?
I know, If I someone will use open cable he obviously will use an MI cable.
I worked in an animal feed mill about 20 years ago. EVERYTHING was covered in a fine flour like dust. On the roof where few people went the plant was covered in a crust - it would rain and more dust would stick to the crust underneath. Don't suppose they would get away with it now. All the wiring was in conduit and it was apparently "pressurised" from an air feed system to stop dust building up and igniting etc.
Conduits between panels have to be designed with flame paths in mind. There’s no point having “Ex” equipment if a passage exists between them to propagate a path.
Please go and study the subject, it’s not one for an open forum!
Thank you very much for your good advices and I will obey as you said.
You are very true that, this is a matter of life so we should be aware be of it and keep it in mind.
Thank you all again for your inputs in my thread.
hhhunzai: Glad to see you've hopefully realised that this sort of system is best Left to fully trained / skilled engineers. Look at it this way: If you were to carry on & install this equipment without the relevant training / skills and were to get it wrong causing an Explosion, it would be you in Prison (And Rightfully so) not the person who told you to do it. They would be sitting back & denying ever telling you to do so.
I think the Pakistani legal system takes a dimmer view than ours of causing deaths so it might be worse than a prison sentence he would need to be worried abouthhhunzai: Look at it this way: If you were to carry on & install this equipment without the relevant training / skills and were to get it wrong causing an Explosion, it would be you in Prison (And Rightfully so) not the person who told you to do it. They would be sitting back & denying ever telling you to do so.
Reply to the thread, titled "Explosion Proof Wiring Systems" which is posted in Electrician Talk | All Countries on Electricians Forums.
