Exposed live wire in cooker wall socket | on ElectriciansForums
Discuss Exposed live wire in cooker wall socket in the UK Electrical Forum area at ElectriciansForums.net
Co down
So I fitted a new metal faceplate switch on the wall socket for my cooker. All went well. As I'm also tiling I took it off a few days later, and noted some of the live wire insulation rubbed off presumably by me screwing the screws in when assembling. I have read of this before, first time hrs happened to me.
I have as an immediate fix put some red electrical tape over the bare wire. Is this enough to do? Should I replace the live wire so its undamaged,if so any particular thickness?
I did see all the sockets had earth cable from face to backbox.
What happens say I didn't note it and the live cable touches the screw holder plate- does it shock you on the faceplate or trip the fuse at the cu?
if you have some bare copper showing on a "live" cable ( and that means both the L and the N, fit some heatshrink of the appropriate colour over it, 2 layers if necessary.
Don't use adhesive tape of any colour, it comes unstuck after a while.
Sleeving is what you need.
PS We dont use red any more, its brown now.
Red tape is just used by plumbers to mark a cold pipe, or is it the hot one?....
it's so confusing this plumbing stuff..
Hi John - if you can post up a pic and we might be better placed to advise on next steps. I'm a bit concerned for you as it's now got a metal front, so please make sure it's off at the Consmer Unit before taking it off the wall.
Sleeving for sure. Needs sorting as you state the metal faceplate is a concern (even in plastic, I would use sleeving and more care with the screws).
Well, being as how you are in Eire or Ireland or wherever I would just keep my head down and hope to God that the electrical police don't come round tomorrow.
Wires are 19 years old, not in a bad state. Pretty satisfied I done it screwing the faceplate back on. Have ordered a heatshrink kit so with cover it better that i have with tape.
You said that some of the insulation 'rubbed off'.
They're not old rubber insulated cables where the rubber has degraded so much that it disintegrates when you touch it?
Reply to Exposed live wire in cooker wall socket in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
And metal backboxes partly full of pink plaster smacks of lazy DIYers, or equally lazy professional sparkies.
Live wires under floorboards? any years ago, when my daughter was just a crawling stage, we were having a new carpet fitted in an upstairs room...
