Extend ring and add a spur | Page 3 | on ElectriciansForums
Discuss Extend ring and add a spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That one in post #26 is better if I upload it and then enlarge it on my PC.
Can just about make out the words original cable.
I'm assuming, that the pink lines at the bottom are the extended ring conductors, and the line to the left are the spur.
Looks alright to me.
Right, assuming my diagram is visible now, is there anything else I need to consider before starting to attach stuff to the wall?
I would say that if your washmachine and dishwasher are 'under counter' then you might wish to supply them through a fused spur x 2 above your worktop down to a single socket x 2. So that you can isolate them without pulling them out to unplug.
Reply to Extend ring and add a spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
I thought I'd add a few photo's of the overall situation we find ourselves in and the general standard of the building work, which is why going...
