Extend SWA to consumer unit | on ElectriciansForums
Guest viewing is limited
Discuss Extend SWA to consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Dinstable
Hi guys. I have an old out building that has been knocked down and in it’s place an extension is being built. The old out building had a ring and a lighting circuit with water heater for a shower all fed From a ccu that came from the main house through 10mm swa. The extension is now going to be fed from this same ccu. However I want to move the original position of the ccu. Can I extend this SWA? And how??
Hi - yes SWA may be extended, but you probably will benefit from the on site help of an Electrician. SWA is a specialised cable and there are a few skills to getting it glanded correctly.
Yes, resin joint, or wiska box a picture would be handy for better options
Assuming it is 3-core 10mm SWA then something like this (if 2-core they reccommend the S6 kit):
But you have to read and follow the instructions carefully. Really I would not plan on doing your first resin joint for a "it matters" buried location...
Hi guys. Sorry it’s overground. Going to have ccu one side of corridor now she what’s it other side of the corridor. As you can see in picture. SWA is on the right where ccu was going to go and cables on the left where ccu is now wanted. SWA not long enough to feed other side of corridor.
  • [ElectriciansForums.net] Extend SWA to consumer unit
Reply to Extend SWA to consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Issue is certain sizes of cable may theoretically be okay but upon the proper testing when it’s commissioned things like a thing may not test out...
