Extend SWA to consumer unit | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Extend SWA to consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Dinstable
Hi guys. I have an old out building that has been knocked down and in it’s place an extension is being built. The old out building had a ring and a lighting circuit with water heater for a shower all fed From a ccu that came from the main house through 10mm swa. The extension is now going to be fed from this same ccu. However I want to move the original position of the ccu. Can I extend this SWA? And how??
As per Mike, SWA channelled across floor and CU located so that the door won't bang into it.
If you put it above the door it's not very accessible if anything ever trips.
Reply to Extend SWA to consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Issue is certain sizes of cable may theoretically be okay but upon the proper testing when it’s commissioned things like a thing may not test out...
